It is a Pvr 6200T Uk
SOURCE: sagem pvr 6200T UK freeview box, display frozen.
I left the box and went for a walk!!!
About four hours after having freezed an error 09 message came up on the set top display and then everything returned to normal, after an on TV screen message that update had been successful.!?!
No difference in in any operation of the freeview box.
Note to self and other users
DO NOT PRESS OK WHEN ASKED TO UPDATE SET TOP BOX.
Updating the channel tuning does seem to work ok, though I have to vary between where channel 4 can be found - or learn welsh!
SOURCE: Retrieve deleted voice message
I don't think this can be done. I read through the entire manual and there is no mention. I can email you a copy of the manual if you want.
SOURCE: My sagem DVR 6200T UK displays ER 07 on the box
I HAVE HAD SAME PROBLEM. I HAVE TWO OF THESE RECORDERS AND ONE IS OK. I SWAPPED THE POWER LEADS FROM THE GOOD ONE TO THE ONE THAT IS NOT WORKING AND IT WORKED SO ALL YOU NEED IS A NEW POWER LEAD FROM SAGEM IN FRANCE.COST £10 PLUS POSTAGE.
CHEERS
SOURCE: Sagem 6200T
The Sagem PVR 6280 is specifically listed as a model which will have
problems with the retune. Although the Sagem PVR 6200 and 6200t are not
specifically listed as problem models they are very closely related to
the 6280/6240 models and share most of the same firmware and software.
See
the address below for a chart of affected models, you'll need to contact Sagem directly on 0845 0900 316 for
either an over the air update or an update DVD depending upon the
manufacturer.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
Sorry
I can't provide you with a definite solution but it's very likely that your model is one of those which only Sagem can sort out.
Please return the favour by rating my answer.
