SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
SOURCE: Konica Minolta bizhub C253 - Displaying status on a webpage
the hp web jetadmin is quite good, it displays whatever info you select. use version 10.2
SOURCE: how to clear error code c 3421 on konica bizhub
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
SOURCE: como vou resolver o erro
Its a fuser code. To reset it the code and get it to work again.
1)Turn the main power off ( the switch behind the toner door )
2)Hold down the Utility button while you turn the machine back on.
3)Keep holding till you see "Trouble reset"
4) Push trouble reset then turn off and on the machine and will start working
As the Installation Manual and Imaging Unit replacement instructions mention, pay close attention to shaking the Imaging unit properly to level the toner and also keeping the Imaging unit level when installing it into the machine
