Garden Logo
Samuel Sammut Posted on Aug 31, 2018
My Karcher turnes electical gircuit breaker of
I have a hd 3.7/22-4sg karcher power washer the green light comes on and after a couple seconds it pops the breaker. will not do anything
Which breaker does it trip? The MCB or the RCD?
If the former, the motor is taking too much current and that might be caused by shorted turns, a defective centrifugal switch (if fitted) or a shorted start or start/run capacitor.
If the unit has been standing for a while it could be the pump is frozen - some units provide access for a hexagon key so the pump can be turned manually a couple of revolutions before switching on the power.
If the RCD has tripped it is because there is an insulation breakdown and current is leaking to ground.
1helpful
My karcher pressure did turn on but stopped working altogether now wont turn on
Make sure that your circuit breaker did not go off and you have power..
Turn on the water after connecting the hoses. Then connect an ohm meter to the hot and ground legs of the male power plug. Push the on/off button to on and then pull the trigger. When you do that your ohm meter should indicate the resistance of the motor windings. If the resistance still stays at zero, then 1 - your motor is burnt out, 2 - the on/off switch is not working, 3 - the water pressure switch is electrically open. Check all three for proper operation and replace as needed.
When turn on power fuse/breaker trips on power up
try to free the motor by turning it somehoe if its free replace running capacitor
2helpful
Karcher 4.91 checked fuse that is ok but no power
Check and see if you are getting power to the on/off swith. These switches have been known to go bad. Also, check the Ground fault breaker in the plug. Let me know how you make out.
2helpful
Electric oven and stovetop do not work, clock and oven light do.
Sounds like you are only getting 120 volts instead of 240 volts. Either a house electical problem or wiring in range. First go to your breaker and turn it off and on three times and give it a little extra push each time you flip it. ( You can actually flip a breaker off and on without resetting a blown breaker if you doni't push it all the way off and all the way on. If the breaker throws itself off do not reset it. You have an elecrical short in your house or range. If resetting the breaker does not work then you need to test for 240 volts coming into the range. We don't recommend you do any electical testing unless you know what you are doing with electicity. If you have 240 volts going to the range then unplug your range and remove the backing panel off the back of the range. Look for burned wiring or terminal blocks. If there is nothing obvious then you need to know how to read a wiring schematic and use a electical tester to go any farther. Let me know if this helps. Good Luck, Appliance Specialists
2answers
Karcher 3.99 electic pressure washer. Compressor/pump run but do not build up high pressure.
check filter and manually adjust pressure by screwing down---clockwise thebrassnut on the outlet side
Jul 26, 2009 • Garden
2helpful
Re - karcher 330
Overload contition in circuit. Turn some stuff OFF.
Ceiling fan just stopped working. Turned on
did any outlets stop working, mat be a tripped or bad breaker in elect. panel she if one breaker is tripped. flip off and back on, could se short in fan but unlikely. if cannot see tripped breaker, turn off computor, tv, any appliance you have on and go down breakers and flip off and back on. if a short is present one breaker will trip back off. call repair
I have a Maytag Neptune Elect dryer MDE9700, that won't heat. It worked fine until yesterday. A breaker kicked off, I reset the breaker and now dryer will work it just doesn't heat up. There is no error...
Your heat strip has burned out, shorted against the frame, and kicked the breaker. Take off the back, it is not hard to replace. Be sure all breakers are turned off.
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
