Computers & Internet Logo
J
Julius Grodski Posted on Aug 31, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
VoIP issue: browser says: Safari can't open the page "19.168.0.170" because Safari can't connect to the server 192.168.0.170, which my telephone when connected to Linksys ATA ; what am I to do?
Using latest Mac with new Archer C7 router, Linksys ATA, trying to set-up VoIP after network failure; router lists LinksysPAP as a DHCP Server, a wired client showing the same ID, but the ATA phone light is NOT on and the browser can't connect to the server; what am I to do to resolve the issue?.
Marvin
Level 3:
Top Expert:
  • Linksys Master 85,242 Answers
  • Posted on Aug 31, 2018
Marvin
Linksys Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29026566
Points
266281
Contact MAC support.
5 Related Answers
Anonymous
  • 49 Answers
  • Posted on Oct 15, 2007
SOURCE: Router unable to connect to internet
Are the info coming from PC connected to modem?
If you are connected to Router and pulled up that Data, you might just need a power cycle. Turn off everything from PC to router - to Modem and Power on everything starting off with the modem this time. After power cycle, check if getting the same data. If yes, then type "ping yahoo.com" if you have four replies then you must be able to go online, if not then disable firewall (norton, maccafee etc)
Anonymous
  • 18 Answers
  • Posted on Feb 01, 2008
SOURCE: PS3 can't obtain IP address through LAN switch
wonderful! that's always a good thing to hear - sometimes it is the "make sure you're power cord is plugged in" problem, eh :)
Anonymous
  • 9 Answers
  • Posted on Mar 22, 2009
SOURCE: Installing
1. if your internet service provider did not provide these to you, they would stay blank. (most cable broadband internet would have these blank, for instance)
2. because you havent entered any dns entries. more importantly, most of the time what is more important is that you router is set to obtain dns from your ISP (service provider) if that is set correctly, its ok that they are all 0's
3. whether or not your connection should be set to the automatic type can only be answered by your service provider, most cable and some DSL broadband would be set to automatic, some DSL will be set to PPPOE, which will require the username and password given to you from your ISP. If they did not give you one, most likely this would be set to automatic.
4. DHCP server functions is what allows your individual computers in your home to share the internet if you have more than one machine. even if you do have just one machine, it should still be set to automatic.
5. The router name is for your reference, so you should name it something that is meaningful to you.
Jim Thomson
  • 1099 Answers
  • Posted on Nov 17, 2009
SOURCE: Connecting Mac to new wireless router. Getting
Go to System preferences then under internet and network in the left hand column click on + sign at bottom of the column then under slect the interface choose airport click on create and then click on turn airport on and then select your network name and if a password is asked for put in the password.
If airport does not show up it probably means that your mac does not have a wireless card in it.
Hope this helps.
govinda123
Prashant M
  • 2278 Answers
  • Posted on Mar 13, 2010
SOURCE: I am unable to set up my Linksys WRT150N router security
Is there any computer connected to the router ?
If not then you will need to connect the computer
to the router.
Do not change any wireless settings on the router
with the wireless computer.
you will need to connect the computer to the
router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the
router.
Now once you change the network anme and security
on the router, you will need to connect to the
wireless network on your wireless computers.
Click Here for step by step instructions
1helpful
2answers
How do I find my home page?
Quit the browser by pressing Command + Q together. Then open the browser again. If that worked you should see your home page. If you want to get back to your home page quicker next time you can turn on the home button in the navigation bar. It's not there by default but you can add it.
It would be helpful to know if you are using Safari or Chrome or some other browser. My bet is on Safari so here's how to do that in Safari.
1. In the gray area next to the address bar, right click or ctrl + click this empty gray space and you will see an option to "Customize Toolbar..." Click on that option.
2. In this next window that appears drag the home button onto the toolbar.
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Safari not connected to the server
Sounds like your wifi connection is down. If other pages will load, it's the server hosting this page which is down.
On my iPad it keeps saying safari cannot open the page because it could not connect to the server.
Either the website you're trying to go to isn't available, or you're not connected to the internet. Make sure you're typing the correct site, and that you are connected to Wi-Fi.
I have compaq c700 laptop, i connect usb network modem ,only i am able to connect voip only, but when i open the browser(internet explore,chrome etc) page it was not connected
Im not sure what kinda modem you have ..but I think if you connect it via usb you need to install the driver for it ...so ..if you have a driver cd ..run it and make it be seen by the computer ..Usually the modem can run without driver but only on the network port in the network card ..This explains why the phone works and not the internet connection itself..Either use it in the Lan card port ..and make the settings you need for the network ...by log into it using it's IP address in the browser ...or install the driver and try to connect it by usb ..
I have polycom SoindPoint 301 and i would like to use as SIP to one of the VoIP providers. I dont have asterisk in my network and i would like to connect it directly to the VoIP provider. So there is no...
1st. Get the IP address of the phone. and type that into browser.
*- default user: Polycom / password: 456
*- Under menu SIP, type in your voip provider
*-Under menu LINES type in user info and "secret" should be your password.
Make sure your ports are open (SIP is usually 5060) you can change it in that same config screen.
2helpful
2answers
Safari could not open the page because the server stopped responding
this happens from time to time the server you may be accessing is taking to long to respond (litterally) and there is a time out when safari gives up. try rebooting ipod or get closer to the connection i suggest installing opera or another browser i think they now have fire fox or chrome. much faster connection let me know if this helps love positive feedback! and comments lol
2helpful
IP address
your voip enabled phone uses dynamic ip addressing so doesn't have a fixed ip. however if you want to configure the phone Connect the WAN port of the SPA922 to your network (router, switch or hub). Make sure that you have a DHCP server so that the SPA922 will get the IP address.
To login to web based administration follow the steps
Access the web based setup page of the SPA922. Verify the IP address through the LCD. Click Menu then press 9. It should show you the DHCP IP address. Open a browser and type that in the Address bar.
Click Admin Login .
Note: The SPA922 does not have a username and password by default. If you are asked for a username and password and you have not configured a password, it means that the SPA921 is locked by your VoIP provider. You need to obtain the password from your VoIP provider.
if this helps resolve your issue please vote for me. thank for using fixya.
Safari not responding to Facebook Home and Profile pages
The problem is probably to do with the servers being clogged up with users but in any case if i were you i would update to the latest flash and java software then restart the computer.
Get Adobe flash here >>>>>>>
http://get.adobe.com/flashplayer/
And Java here >>>>>>
http://www.java.com/en/download/index.jsp
Good luck.
1helpful
Error message server is not responding
Server is busy, or the time to have page load has elapsed. Try to refresh it. Or try another web browser.
It also appears when your offline or no signal from the isp.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
