My ruud model number is upla-041JAZ. Dividing 41 by 12 equals 3.5 is that the correct calculation for tonnage?
SOURCE: Central Air will not come on.
You can get it at www.myhvacparts.com you dont have to be an a/c contractor to buy parts from them.
SOURCE: I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
SOURCE: I have a Ruud AC model UACC-056jas serial number
That would be a nominal 5 ton BTU unit or 56,000 btu....
At 12,000 btu/ton you can see that it is just a bit short of 5 ton but larger then 4 ton....actually about 4.75 ton....
heatman101
Testimonial: "Great! Thank you for the very quick response!"
