18Bravo50 Posted on Aug 30, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 Jeep Cherokee Limited stock radio FM signal and channels are weak and not receiving most local stations.
john h
Level 3:
Top Expert:
  • Jeep Master 29,494 Answers
  • Posted on Aug 30, 2018
john h
Jeep Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7551863
Points
193449
5 Related Answers
Anonymous
  • Posted on Nov 21, 2008
SOURCE: 2005 jeep grand cherokee radio
It's in the engine compartment IOD#2. It's a black module with two fuses in it. Take that module off and replace the 20 AMP one.
FoRdMaStEr
Ernest Stalker
  • 53 Answers
  • Posted on Jan 07, 2009
SOURCE: Can not set the clock on my 2005 grand cherokee limited
im a tech at a jeep dealer and i always have trouble remembering how to set the time. but i do know that it is in the navigation menu somewhere under settings or something i hope this helps
Anonymous
  • 716 Answers
  • Posted on Jan 12, 2009
SOURCE: How to set radio station memory for jeep cherokee 2000?
Go To The Station You Want In The Memory And Press And Hold The Number You Want It On.
gadgetmen53
  • Posted on Jan 28, 2009
SOURCE: How to test r/c transmitter for 27 & 49mhz using am or fm radio s
I went to wisegeek.com & they took care of problem & did not cost a penny. What happened to your site where it says Let our Expert solve your problem for FREE. Who wants to get advice from someone that does not know how to tell the truth & doesn't know right from wrong-Bye charlie lockhart
biigg53566
Alan Matzke
  • 113 Answers
  • Posted on Feb 19, 2009
SOURCE: No Signal on Lubbock, TX channel 11.1 but receive all others
When the Government decided to make all stations go digital, most places we're telling about the change over. But what they forgot to mention to the ones like you that you may have to change your outside antenna. They make antenna just for picking up digital signal. So you may have to change that also. be Sure and check the cable going from the ant. to back of the converter box is in good condition or may have a break somewhere that could cause more trouble. If you see any bad places on the cable you may want to replace it now when you do the antenna.
biigg53566
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
NO AM STATIONS IN MY 1998 JEEP GRAND CHEROKEE, BUT NO PROBLEMS WITH FM. DO I Have to change or repair the radio or the antenna?
A.m. radio stations have a very limited range and honestly modern units include am reception as an after thought. Unless you are within a few miles of the station you probably won't pick it up. That being said if you are close enough and still cannot pick it up then the radio is probably faulty.
AM/FM radio how can get sound back?
a bad antenna tops list. or the cable fell off to it?
got static with volume up?
sure.
if you remove the ant. jack and put finger on the hot pin inside
you will become a human antenna, and pickup close local stations
or use a length of any wire, to put there and get lots of stations
if that works the radio is ok and antenna is bad.
we do this bench testing.
2answers
I have a 2008 Jeep Liberty.The radio will not come in at all.No matter what channel I try,it comes in static
You have lost the antenna. It either fell out(seen this) or the receiver in the radio is dead.
My stereo in my jeep will only play am stations no ft stations anyone know how to fix this
stock radio or not? we can not guess that (we blind)
if far from FM stations and close to Am
many good radios, ;play AM ok, and not FM
so the antenna is bad, make or use a test antenna, and BINGO facts. speak.
FM Transmitter does not connect to car radio, have FX signal and Line out works.
Car cradle works "wirelessly" with Car Radio (inherent design of unit). Place Unit in Cradle; connect Cradle to Auto Power Source, and SkyFi3 should power on. Press Menu to Get FM Radio station channels; select a lower station Channel Frequency i.e. 88.3 or any vacant channel number and the signal should transfer to your Radio speakers automatically. You can change Station frequencies as often as you need to do so--for example if traveling through different broadcast areas, some channels frequencies are clearer than others. Good luck.
2008 s40, i have no am signal but FM plays and CD no problem
There is a possibility that the radio is set to receive ONLY very high quality, strong signals. Maybe you are just getting the strong FM signals, and not the weak ones, and that all your AM stations are weak. When set on this mode, you dont hear the white noise of weak stations, the radio automatically blocks them out.
1helpful
2answers
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
 Mikey
Mikey
Stan Ford
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
