SOURCE: Kenmore Sewing Machine Model #158.18032
You probably have a bind in the feed dog mechanism. If you can remove the covers and manually force them down you will see the hinge points that need to be oiled.
Unplug first!
Good luck.
SOURCE: Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
SOURCE: How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
SOURCE: I can't drop feed dog on my Husqvarna viking 230
It sounds like maybe you have it set up to make button holes.
I have a Kenmore 150 also and this morning it started not pulling the fabric through. I flipped the feed dog switch a few time but it didn't help. So I removed the two screws that hold the plastic casing on under the feed dogs and piles of fabric/thread fuzz came out. I brushed and blew all the fuzz out and now the feed dogs are back to normal! Love this little machine!
