SOURCE: Caller ID doesn't work?
There are four double A batteries in the bottom you have to install (or change). After your first incoming call, the time and date will be set automatically and the caller ID should start working.
SOURCE: caller id
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
SOURCE: Caller ID Stopped Working - Think the phone needs to be reset?
Not sure why this worked, but I went to the Menu and the Set Area Code selection. The area code setting was blank, so I entered my area code and saved it. Caller ID started to work again. As a test, I went back to the Set Area Code selection and deleted the area code and saved it. It is currently still working. Seems really odd, but it worked for me.
SOURCE: Caller ID Light Won't Stop Blinking on Base of KX TC1713 Phone
Solved this myself simply by scrolling through all the Caller ID entries from recent calls . . .
SOURCE: MagicJack Caller ID problem...
I found this solution. It worked...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190398696713
