Dryers Logo
a
angela oumarou Posted on Aug 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the thermal fuse located on a Haier encore dryer model Rde350aw
brian williams
Level 3:
Genius:
  • Master 1,980 Answers
  • Posted on Aug 29, 2018
brian williams
Master
Level 3:
Genius:
Answers
1980
Questions
9
Helped
740804
Points
5402
Usually close to heating element
2 Related Answers
Michael Carroll
  • 742 Answers
  • Posted on Feb 15, 2015
SOURCE: picture of thermal fuse on haier rde350aw location to be removed and tested.
More than likely a bad heating element
shawnearth99
Fran Roles
  • 88 Answers
SOURCE: where is the thermal fuse on haier dryer rde350aw located
Inside the back attached to the exhaust plenum.
Where is the thermal fuse on Haier Dryer model HLTD600AEW?
The location of the thermal fuse on a Haier Dryer model HLTD600AEW may vary depending on the specific model and design of the dryer. However, in general, the thermal fuse is usually located near the heating element or the exhaust duct. It may be hidden behind a panel or tucked away in a hard-to-reach area. In some cases, it may be necessary to consult the user manual or contact the manufacturer for specific instructions on how to locate the thermal fuse on a Haier Dryer model HLTD600AEW.
1helpful
2answers
I have a Haier dryer model GDE480BW. The lights come on but when I push start it only clicks. If there are fuses to be replaced where can I locate them and what should I be looking for?
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/1--2132624-/new/Dryer-won-t-start-GDE480BW
Your issue might be the thermal fuse. This page goes over that and other potential causes for your model dryer.
The clicking could be the start relay or the door switch ... hard to say.
Good luck on your troubleshooting
Where is the thermal fuse located on a Haier RDE350AW dryer ?
Not exactly a fuse for drying heat, the electric motor would have a thermal fuse strapped into the winding.
The dryer exhaust hot air chimney, just after the drum, would have both a thermostat and a high heat limit called thermodisk cut off and clixon by trade name.
Find the wiring diagram inside the dryer panels to reveal color wires going to what you need finding.
My Haier Dryer Model RDE350AW only clicks when I press start button, any suggestions?
Since the start relay is clicking it is likely closing the circuit and sending voltage to the dryer motor. You may have a defective thermal limiter fuse blown, it is near the dryer motor so you must remove the back or front of the dryer to access it for testing. Always unplug the dryer before any work is done. You will need a DVOM meter (about $10.00) to check the fuse for continuity.
1helpful
Where is the thermal fuse on haier dryer rde350aw located
Where is the thermal fuse on haier rde350aw ?
Either on the heating element or right next to the blower fan
Nov 05, 2014 • Dryers
MODEL # RDE350AW HAIER HAS POWER BUT WONT START MAKES CLICKING SOUND
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Top Haier Dryers Experts
Mike Cairns
Mike Cairns
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Haier Dryer Expert? Answer questions, earn points and help others
