If your onn bluetooth boombox is no longer able to read CDs when using battery power, it is possible that the batteries are not providing enough power to the CD player. CD players require a lot of power to spin the disc and read the data, and using low-quality or weak batteries may not be able to provide enough power for the CD player to function properly.
Here are some steps you can try to fix this problem:
- Use high-quality batteries: Make sure that you are using high-quality batteries in your onn bluetooth boombox. Low-quality batteries may not be able to provide enough power for the CD player, and they may also leak or corrode, which can damage the CD player and other components.
- Use fresh batteries: If you have been using the same batteries for a long time, they may have lost some of their charge and may not be able to provide enough power for the CD player. Try replacing the batteries with fresh ones to see if that helps.
- Use rechargeable batteries: Rechargeable batteries may be able to provide more consistent and reliable power to the CD player than disposable batteries. If you are using disposable batteries, try switching to rechargeable ones and see if that makes a difference.
If these steps do not fix the problem, it is possible that there is a problem with the CD player itself. In this case, you may need to contact onn customer support for further assistance. They will be able to provide more specific troubleshooting steps and help you determine if the CD player needs to be repaired or replaced.
