Question about Nortel Lands Phones
Nortel Flash ask for key after feature 983 - Nortel Lands Phones
SOURCE:
SOURCE: Nortel T7316E
I will share how I've learned and "that's the hard way". In your search engine, type in programming for notel meridian 7310 and you will find several that provide comprehensive programming.
In the notes I have printed, to log into System Administration,
Enter Feature 983 (the display will show "LOG" and then enter your password.
Your password depends on the number of digits for each extension number:
If your company extensions are 2 digits long enter "120000"
If your company extensions are 3 digits long enter: 1020000"
If you company extensions are 4 digits long enter: "10020000"
Another useful feature is FEATURE **23646 AND THE PASSWORD IS 23646, all you need to do is follow the overlay prompts.
Posted on Mar 13, 2008
SOURCE: ADMIN PASSWORD RESET FOR NORTEL T7316E SYSTEM
If your company extentions are 2 digits long enter "120000"
If your company extentions are 2 digits long enter "1020000"
If your company extentions are 2 digits long enter "10020000"
Posted on Feb 27, 2009
consultel1
  • 860 Answers
SOURCE: I am locked out of
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000.
Posted on Dec 11, 2009
Testimonial: "OMG THANKS SO MUCH!!!!!!!!!!!!!! YOU FIXED IT!!!! THANK YOU THANK YOU!"
consultel1
  • 860 Answers
SOURCE: I used feature 983 to delete a few old mailboxes.
It sounds like you've either deleted your own mailbox or reset the password to 0000 and changed the password to the administrator mailbox. To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000. 1020000 if you have 3 digit intercom numbers. Once that's done you can go into admin programming to default your password back to 0000.
Posted on Sep 02, 2010
Testimonial: "perfect consultel1.... your advise was right on the money and i didn't even have to try twice:) but now how do i set up the general voice mailbox to work with "Feature 986" all other extensions seem to be working fine. What should my service class be? "
  • 3278 Answers
SOURCE: Nortel T7316E callpilot voicemail is
Hello.
From FixYa Support:
How to Change a Mailbox Password
1. To access the voice mail system press Feature.
2. Press 9 8 3.
3. When you see Log: enter ~ SETNNA (738662) and press OK
4. Pswd: CONFIG (266344)
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
Hope this helps.
Posted on Aug 25, 2011
Locked out of Nortel t7316 every time you press feature and #983 or 985 it displays inactive feature.
F983 and F985 are voice mail access feature codes. Try rebooting your voice mail system to see if the unit recovers. There is no switch so you will need to unplug the power to the VMS to reboot.
Jun 29, 2015 | Nortel Lands Phones
We need help with our Nortel system (T7316E). We don't know the admin password. We have tried Feature 985 and then it says to hit "9" but we can't do that as the display shows VM:363 and we can only hit...
feature 985 shows you your vm extension #.
feature 983 then try 1029999 (if password was changed to 9999 or something else)
or maybe feature 983 then 738662 'ok' then 266344 'ok'. depending on the norstar system you have.
these are some codes to enter the vm management. What are you trying to do, reset a vm password or other system programming?
Apr 17, 2014 | NorStar T7316E Corded Phone
Admin nortel i can't access the adminstrative programming. i enter feature 983 and it says "inactive feature". how can i fix it to where i can set up a new mailbox?
If you are getting inactive feature when entering feature 983 the phone system and voice mail unit are not communicating. This usually requires a power reset to clear. Or the voice mail unit is in trouble and a vendor needs to be called.
Aug 12, 2013 | NorStar T7316E Corded Phone
My MBOX is locked on my T7316E Nortel phone. Also, trying to retrieve messages from home I somehow changed the password and I don't know what it is.
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
Feature 985 will show you your mailbox extension
Apr 25, 2011 | Nortel T7316E 2-Line Corded Phone
How do i unlock a mailbox on the Nortel PBX - Not the main PBX.
From the main phone you have to go into admin feature 983 then password 120000 for 2 digit locals 1020000 for 3 digit locals 10020000 for 4 digit locals etc. this gets you in to vmail programming type in the local or mailbox no. then reset password for that mail box which will go back to defult password which is 4 zeros 0000 got it then go to phone and when setting up vmail it will ask you for password enter 0000 then it will ask you to change password enter what you want. Hope this helps
Jan 14, 2010 | Nortel Norstar 16-Line PBX Speakerphone
I am locked out of my admin mailbox on my nortel nt8b26aabl phone, when i use feature 983 and then password 102000, it says invalid password.???
Dec 11, 2009 | NorStar T7316E Corded Phone
Nortel 7316e: Need to change the auto attendant
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Oct 27, 2009 | Nortel T7316E 2-Line Corded Phone
Password issues
To reset a subscriber mailbox press feature 983, enter in log (default 1020000), on the 3 soft keys bolow the the screen press mbox,chng, enter extension number of the locked mailbox, press reset at the reset password prompt.press rls key
Oct 09, 2009 | Platinum Norstar T7208 Telephone
Nortel norstar
ON NORTEL DO A FEATURE 983 PASSWORD IS GOING TO BE 120000 AND THAT WILL PROMPT YOU THRU RESETING THE PASSWORD IF THAT DOES NOT WORK DO A FEATURE 985 PRESS 9THEN TYPE IN (RESET SM ) THEN TYPE IN (PSWD) AND IT WILL GO BACK TO DEFAULT . PS THE SM STANDS FOR SYSTEM MANAGER
Jan 25, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Lands Phones Logo
82 people viewed this question
Top Nortel Lands Phones Experts
Sanjaya Sahu
Sanjaya Sahu
deton8 von Splosion
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
