This is one of those cribs that converts to a youth bed and then a full-size bed.
SOURCE: Jardine Black Olympia lifetime convertible crib
I called Jardine Enterprises and they said they would email me a manual . Call them at 1-800-295-1980 and provide them with the model number and mfg date of your crib and they will send you a manual via email.
SOURCE: Instructions for converting Jardine crib to day bed model 0308C00
This crib is on the recall list, depending on the date of manufacturing. PLEASE check this out! We have the same crib and I just found this out today. see http://www.jardinecribrecall.com.
SOURCE: converting crib to full size bed
I just finally got my full bed put together and it was really easy and looks great! Ok so I called Jardine enterprises and they told me to call Sleepy's and ask for a Universal hook-on metal rails for a crib. So I did that and the Sleepy's I called said they were discontinued. I continued to call several more Sleepys till I got someone who told me that they were indeed available and he knew exactly what I needed...he just converted his 3 year old's bed. He was right and everything worked out perfectly. The gentleman I spoke with at Sleepy's is Damien. Your best bet is to call him no matter where you are located and he will order you exactly what you need or tell you which location to pick them up from. He is in a Sleepys in NJ #201-487-4242. They can deliver it to you and I think the charge is $90...well thats atleast what mine was but they also delivered a full box which I HIGHLY RECOMMEND because the bedrails make the bed really low to the ground and it does not look good that way. I have the manual for converting the kit if you decide to do it on your own. If you need it just respond to this answer. One more thing that I did not realize when the bed rails came and I thought they were not what we needed. You need to follow the instruction manual because it is very important that you take your crib apart completely to get both headboard
SOURCE: Lost instructions for Jardine Madison Crib
Many times the manufacturer puts the conversion instructions on the bottom side of the flat board that fits under the mattress. Remove the mattress, flip over the flat board, and see if the instructions are there!
