Health & Beauty Logo
Cindy Wenger Posted on Aug 28, 2018
Cmt HS-5600 scooter why does a wrench light indicator on joystick panel flashes 7 times when you move joystick in any direction?
My Jazzy Select HD stopped working. It turns on, but wont move. I have chasing lights going from left to right. I tried unlocking, that did not work. Any other ideas?
make sure that the free wheel levers are in drive position. Also the charger is unplugged. restart and see if that took care of it. Also check the wires coming out of the joystick that they have not been damaged somehow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
1helpful
Cmt scooter moves forward or backwards then shudders a little then stops first light flashing on panel please help.
Sounds like the throttle pot is bad and will need replacing, try changing speed level and try again. if it works then speed pot will need replacing. Scooter Doctor App
What do eight wrench flashes indicate?
hi. according to Invacare,, the following joystick is used with the wheelchair you mention...
https://www.invacare.com/product_files/1110532.pdf
goto page 33 for more detailed help
Please let me know how you get on ..
regards
Rob
2helpful
2answers
Yellow wrench light ctm hs 1000
Usually a generic 'trouble' indicator. Can you read out the error codes or fault log?
1helpful
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
CTM Homecare HS-580 Mobility Scooter fault warning light flashing 7 times
Hello,this fault you explain needs giving to the maker of your scooter.I doubt they will deal with you direct,but I am sure they will point you in the right direction.I am disabled myself & love to help when I can.FixYa helps me live,Please update me on how you got on.Have a nice day,Colin.
7helpful
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
This jazzy Select 6 chair battery light keeps flashing 7 times and will not function.
alaker the 7 flashes indicate a joystick problem. Make sure that the joystick is centered before you turn the chair on. If it is centered and you still get the flashes then there is a problem that can only be fixed by a new joystick. Sorry for the bad news. Did Medicare pay for your chair? If they did then they will pay most of the replacement costs. Check with the provider that sold you the chair or with Roadrunner Mobility (On the web) to get it repaired Hope this helps
1helpful
Ctm hs 2800 turn on key light come on and blink 7 time then go out push joystick foward motors kicks in and out and lights blink 7 times and then frist red light keeps flashing
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul****this will be your problem***
8. Power Module Faul
9.Shark Module Faul
Contact me Direct 909-590-1388 x115 CTM HOMECARE OFFICE
2answers
I have a ctm scooter the battries are charged fully when i switch on the scooter will not work switch off and on again it then will travel a few feet before stopping
The joystick will display a sequence of flash codes. Count them and find the count here: This could be several issues, But the flash code will tell you for sure.
3. Left motor Fault
9.Shark Module Faul
Top Ez Access Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Ez Access Health and Beauty Expert? Answer questions, earn points and help others
