Televison & Video Logo
I have a polaroid tv serial #DR7B188556000427 i need the cord that goes from the tv input to my computer
2 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jul 12, 2010
SOURCE: I need a power cord for a polaroid HD TV 81.5 INCH
Try using the power cord from your PC. NEMA5-15P to IEC C13.
Anonymous
  • 1961 Answers
  • Posted on Dec 27, 2010
SOURCE: Lost the power cord for
you can buy this at the Amazon
1. http://www.amazon.com/Replacement-Monitor-Adapter-Power-Supply/dp/B0023Y9EQC/ref=sr_1_1?ie=UTF8&qid=1293476387&sr=8-1
This AC Adapter 12V, 5A power supply comes with a power cord. The one you need.
Hope this helps
How do i use as a pc monitor?
Well if you have an HDMI output on your pc you can use that or if the TV has a VGA input you can use a VGA cord and select your TV input to PC
I'm trying to use a Polaroid FLM-3201 as my computer monitor. The screen resolution is poor, so I have tried to change the settings in the control panel. However, when I do so the Tscreen goes to snow and...
use manual settings for this input. i've had this issue before. when trying to watch movie from netbook, similar message occur. got to manual phase settings, played with adjustment and: ta-da! got good picture. sometimes auto mode for this input is not catching up.
Good luck,
Alex's TV,
Philadelphia, pa.
215-806-5980.
Hello. I just connected my polaroid 32 in LCD HDTV to my computer and there is no sound? I played around with the audio settings on my computer but no luck. How can I fix that? thanks!
You'll need to run an audio cable from your computer's sound card to the TV as well. Depending on your TV's inputs, you will have to get a cable that has a 1/8" stereo plug on one end and either RCA male or 1/8" stereo plug on the other (depends on whether your TV has a 1/8" audio input for the computer connection or RCA inputs.
Missing power cord polaroid tdx01930b tv
I am not sure what you are trying to ask.
If you need to get a new one, try contacting the manufacturer using the link below. If it uses the same kind of cord as a computer power supply you can get that at radioshack.
http://www.polaroid.com/contact
2answers
My 26" lcd television FLM-2601 polaroid is not working it constantly stays in standby mode you push power button and blue light flicks on then goes right back into standby mode how do i fix this?
First of all, check your input source on your TV.
Turn on TV.
Press the Input button on your remote.
Make sure the Source Input matches the corresponding device that is wired on the back of the TV.
I have my polaroid hooked up with an hdmi cable
Thats because your TV is not high definition and cannot process the high def signal. serial hook up does not give a highh def signal.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
2answers
42' polaroid tv wont show screen still
well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
