SOURCE: removing the watch stem
Hi, it depends on the watch . Look carefully ,if there is a release button , somethin you can press on or lift up. Sometimes a needle is enough to do the job. On some quartz movements (the cheap ones) you just can't remove the stem ...
hope this will be helpfull!
K.
SOURCE: Removing the crown
The video i want to see you,is using older kind of watch,screwing before he can pull the crown ,the new model watches now like your Tag Heuer is pushing, use a needle to push, while pushing the stem lock you pull the crown .That's why ill tell you in advance so you aware.I know because i'm a watch technician working in rolex before...
remove the crown
if i helped,please,click FOR RATING .It is the only way i get paid for my works also,please consider leaving feedback..
Regards,
VOTIT
SOURCE: illinois pocket watch stem removal.
First you must say what type as there are differences depending on the mfg and model.Be the following basics apply.
1- Put the stem in the setting position (usually pulled out if stem set).
2 Them open cover to expose the movement. ( Screw off or snap open).
3- Remove the movement (Usually held in place with 2 screws at the outer edge.
4-Then if there is a screw in the part that holds the stem loosen that.
5- The stem can be held with a pair of pliers on the flat and the crown unscrewed. Be careful not to damage the square (FLATS), with the pliers. A rag or other safety measure should be taken.
6- then inside the stem hole, looking from the ouside the is an annular area around the stem that has a ferrule screwed into the case this has to be unscrewed and will bring out the stem and the ferrule.
This siounds complicated but the steps are more involved to write than they are to perform.
There are many variations to this process, and each type should be understood before proceeding.
[email protected]
SOURCE: how to remove stem on timex indiglo WR 30M ?
Insane as it seems, apparently the Indiglo wr30m watch stem does NOT have either a set screw or a release button. No vice needed though, just good fingernails. Pull it out one click to the 'set time' position and pull it out some more and it comes out.
