Screw came loose and now lots of parts and no way to know the proper order to put them all together.
SOURCE: need assembly instructions for baby bed model #012614
I need instructions to asseble jenny lind crib #012614
SOURCE: I have a Hoover Slider,
Greetings from GoVacuum,
Please see the link below for a parts schematic to your Hoover Slider, hopefully this will help you put the machine back together. If you find a part that is missing, and would like to order one, just shoot me an email at chris.jones at govacuum.com, and I can give you a price on it.
Please feel free to send me an email should you have any further questions.
Chris Jones
GoVacuum.com
SOURCE: putting back together correctly after installing new heat sensor
the hoover website does NOT give screw sizes,unfortunately!
cut and paste following info
http://www.fixya.com/support/p40544-hoover_ultra_u6430_900_windtunnel_bagged/manual-4481/page-13
SOURCE: 2003 yamaha v-star 1100 gas cap assembly
You are probably not going to find assembly instructions. If you can't find all the parts or screws then get another cap. Google " motorcycle salvage yamaha " and you can probably find one at a much lower cost than the dealer would give. By the way, forget any loose screws in the gas tank. The stuff can not get past the fuel valve and filter and are not going to hurt anything.
Please rate this answer. Thanks!
SOURCE: need to install drive belt- lady kenmore dryer..loop designation
The belt probably broke first, which caused the idler pulley to come loose. This is normal. With no tension on the pulley it will commonly fall over. To re-install, follow these steps:
1. Loop the new drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. If this is a Kenmore dryer, it will be manufactured by Whirlpool. Refer to diagram H. If you still have questions, please let me know. I hope this helps you.
