SOURCE: 99 buick century won't start, no lights, gauges erratic
hi there its the main fuse in the engine bay i think
SOURCE: Lost all electrical power while driving?
Sounds like a poor connection from either the positive or ground from the battery. Check connections at the battery, follow the cables to see if any other connections are loose.
SOURCE: intermittent electric system outage. no power to
check the bulk connector on the floorboard next to the interior fuse panel. the little bolt may have come loose. also check the wires from the back of the fuse panel going through the floorboard to the engine compartment for any frays or nicks in the wire assembly. Check the fuses and all of the relays and make sure they are tight. May also be a body control module that has been blown.
SOURCE: Have no electrical power
You might have a electrical short draining the battery or a bad alternator.Most auto parts stores will test the alternator for free.Good luck
Check the power circuit with a tester. You can look up for a wiring diagram on the web.
