Heating & Cooling Logo
Paula Blake Posted on Aug 27, 2018
Manual for comfort zone fan CZHV9B - Comfort Zone Heating & Cooling
Comfort Zone CZ230ERG 7,500-Watt, 240v Hard-Wired Digital Fan-Forced Ceiling Mount Heater. Manual please model cz230erg 7500 watts heater.
Question edited for full 'make model (what it is)'.
Question moved from 'Watts Electrical Supplies' to Comfort Zone.
Manual
https://manuals.plus/comfort-zone/comfort-zone-cz230er-7500-watt-digital-thermostat
Comfort Zone Ceiling-Mounted 7500-Watt Fan-Forced ...
comfortzoneproducts.com https://www.comfortzoneproducts.com > products > ce...
Featuring a ceiling-mount design, this tough commercial heater boasts a heavy gauge steel body that stands up to daily use in poorly insulated areas where ...
My Comfort Zone heater comes on and the fan is loud and scraping sound and quits. Then does the whole cycle again.
Question edited to add a few capital letter for Proper Names and model numbers.
Take the cover off and find why the fan is scraping. Sometimes they will move on the motor spindle and hit the casing. If the fan is slowed down the element gets too hot and overheat protection cuts the power until it cools. Fix the fan and it will be fine. Some fans have a small Allen head grub screw in the fan collar, some are press fit with grip washers.
https://www.google.com/search?q=Comfort+Zone+CZ799BK
Comfort zone cz230er roar
can you return it for another one? call comfort zone for help, and warranty replacements parts.
2answers
Where is the fuse for a comfort zone model cz121b ocillating desk fan?
I've never seen a fan with a replacable fuse. There may be a thermal fuse inside the motor windings.
Comfort zone fan- CZ161 won't turn on
Remove front grill cover and spin the fan, if it spins the problem is most likely the on? off switch or the cord may be frayed, at the plug end usually.
Need manual for serial # E0825340 model CZ 1500 wt
my comfort zone cz1500wt shuts off when turned on code A03 appears on the display
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
