SOURCE: jensen VM9512 in-dash DVD player
i dont have solution, but i used this one and it seriously worked.
SOURCE: my jensen dvd player mvb85
I think there are 90% chances of video wire plugged in wrong port... remove the wire from dvd player and tv,, and again plug in after checking your manual. In settings check for ntsc/pal mode, if you have these option, try changing to different mode..
good luck
SOURCE: JENSEN VM9312 CAR DVD PLAYER HOW
go to am/fm
then open the settings screen
next on your remote type 5,4,3,2,1,0 listening for each beep
a new screen should come up
after that look for brake override
SOURCE: Hi if got the jensen
Connect the green (parking brake) wire on the player to the black (earth)wire on the player.
SOURCE: need the Bluetooth pair code
Hi Charles
The factory code is 0000. If a previous user has changed this, you are out of luck.
Mark
