SOURCE: cant save to pdf in printmaster gold 17
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
SOURCE: error message 1305
Microsoft has error 1305 as an "error reading from file." Check out http://support.microsoft.com/kb/248263 And try there troubleshooting, it could be that the disc is scratched or dirty, the drive could be bad, or it may be incomp[atable with the current operating system. The above link is your best first attempt at solving the problem.
good luck, hope this helps.
SOURCE: CAN'T INSTALL PRINTMASTER GOLD 10 ON VISTA COMPUTER
As I just posted on http://www.fixya.com/support/t2129564-printmaster_platinum_10_version_will_not I was able to get PrintMaster Platinum 10 to install on Windows Vista by right clicking on E:\Setup\is_Setup.Exe->Properties->Compatibility->Run this program in compatibility mode for Windows XP (Service Pack 2) and then running E:\Setup>is_Setup.Exe FullSetup.ini from the command prompt.
SOURCE: will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
SOURCE: Can I load Printmaster 16 on Windows 7?
Printmaster 16 will work with Vista and Windows 7, you need to run setup.exe as administrator.
