You can easily reset a Tissot T-Touch watch by following a few simple steps. Press the "T" button on the middle right side of the watch. Push the "Plus" button on the top right side of the watch to advance the minute hand to the correct time.
The Manual recommends a Renata CR1632.
Are you certain you installed the correct battery?
Is your case back screw on or snap on...older models have different back removal methods
Thanks, but this is not very helpful. I can adjust analog time and the hands behave correctly. The gibberish is in the digital window - no matter what I set there, in a few seconds it reverts to the same nonsense. Seems like it is a snap on. The battery was changed by a guy in a watch store (not Tissiot authorized), I assumed he installed the proper one.
SOURCE: No Alarms After Changing Battery
you have lost the alarm spring or put it in wrong spot. it touches the alarmplate in the case back. in some models if the back is upside down same problem.
