Step 1
Wind your clock once a week by inserting the winding key into each of the three keyholes on the front of the clock and winding until the key won't wind any more. Make sure to wind your Linden clock before attempting to set it.
Step 2
Access the clock hands on your Linden clock by opening the glass door on the front or back of your clock, depending on the model. Use the winding key, if necessary, to unlock the clock's front or back door.
Step 3
Set the time on your Linden clock by moving the clock hands to the appropriate time. The hands of your clock can be moved clockwise or counterclockwise.
Step 4
Locate the chime-selector lever that extends from the opening next to the "3" position on the clock dial.
Step 5
Move the chime-selector lever to "Whitt" for the Whittington chime, "St. Mich" for the St. Michael chime and "West" for the Westminster chime. Set the chime-selector lever to "Silent" if you don't want your Linden clock to chime at the top of every hour.
Testimonial: "Sorry, not helpful. This clock is run by batteries. I still don’t know what all the buttons and things do. Thanks anyway."
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
SOURCE: Kenwood KDC-MP208 Clock Set
Make sure that the source is set to "Standby" when trying to access the menu. It took me about an hour to figure it out and afterward I felt like a ******.
SOURCE: Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
SOURCE: Seiko Westminster Chime Clock; Model No. QF0020 (or QF002G)
There is a small potentiometer that the volume know is on, probably replacing the pot will fix the problem. Radio Shack has these.
SOURCE: i have an Elgin anniversary clock (battery
I have a 20 yr old Elgin Anniversary Clock with the Magic Eye battery operated. It chimes 15 mins after the hour. How do I correct this?
