Bosch Aquatech dishwater - I have cleared fault but am left with error code F still showing. How can I reset it? There is no Reset button on this model.
SOURCE: Bosch dishwasher stuck on "1"
YOU MAY NEED A CONTROL BOARD OR A HEATER. THERE IS A CONNECTOR WITH A RED AND GRAY WIRE, THE RED WIRE IS THICKER THAN THE OTHER RED WIRES. IF YOU HAVE 120 VOLTS ON THERED WIRE THE CONTROL IS GOOD. YOU NEED A CLAMP ON AMP METER TO TEST TO SEE IF THERE IS AN AMP DRAW ON THE RED WIRE WHICH WOULD TELL YOU THE HEATER IS WORKING
SOURCE: Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
SOURCE: My Whirlpool Washer Cabrio model# WTW6200SW has a
Called 1-800-253-1301 was told by the Whirlpool agent that there was a quality issue associated with the F1 fault code. They would take care of parts and labor free of charge! My machine is 28 months old. Talked to a woman named Valerie.
SOURCE: Blinking Green Light
I got the blinking clean light x 7 and I ended up resetting the unit and everything was fine thereafter. You can reset the unit by pressing "heat dry" followed by "normal" forllowed by "heat dry" and lastly "normal." Dishwasher reset and went through a 16 minute cycle. After that, it ran fine. here is a linked that helped me.
http://video.google.com/videoplay?docid=-973702559038457901#
SOURCE: how to clear a delonghi dishwasher error code 4
Try removing all dish trays and salt softner lid, check if the salt softner compartment is full of water, if so place the machine on its side and allow all the water to drain from the compartment, once this is done your machine should be good to go. This is how i resolved my problem. The salt softner is located next to the water drain filter.
