SOURCE: keyboard replacement instructions
The keyboard removal process is very similar to many other laptop brands.
1. Remove screws securing the keyboard.
2. Remove keyboard bezel.
3. Unplug keyboard cable from the connector on the motherboard.
A word of caution. Be very careful with the connector on the motherboard when you unlock it If you accidentally break the connector, you’ll have to replace the whole motherboard.
You can even try this site http://mycapsules.com/disassembly/fujitsu-s2110/keyboard
or this site
http://www.amilo-forum.de/topic,1056,-Arbeitsspeicherwechsel-RAM-bei-Amilo-Pro-v2010.html
It is not your model but it will give you an idea.Just keep pressing "next"
Hope it helped.
SOURCE: How to change and upgrade the memory
on the bottom of the laptop is a square plate with 1 or 2 screws, when the laptop is off, remove those screws and you should see your laptop memory, gently expand the two thin metal clips on either side of the memory and it should pop up at an angle, gently remove it and replace with a larger capacty memory module.
SOURCE: does the fujitsu Siemens Amilo pro V2010 have a
Backlight is connected to the lcd so that the display become brighter and readable.
why do you want to take it out?
SOURCE: where can i find the
Type in your browser Fujitsu Siemens support.
One heading will say support Fujitsu and under it the first heading will say downloads click it.
Where it says
Please enter either the Serial-/Ident number or the product name enter the ID that is on the base of the laptop all the drivers for that model will be listed and available for free download.
If the code on the base of the laptop is unreadable use the next box down
SELECT PRODUCT
First rectangular box in the drop down menu select notebook
Second rectangular box in the drop down menu select AMILO Pro
Third rectangular box in the drop down menu select Amilo proxxx
Fourth rectangular box which says please select product in the drop down menu select V2010
Select your operating system and all the drivers will be listed in categories which you can download free of charge.
Hope this helps.
SOURCE: driver fujitsu siemens amilo pro
HI,
You can download the driver from the below mentioned website.
http://ts.fujitsu.com/support/downloads.html
