SOURCE: com port
IR port --> in AS just go to "file\connection settings" then tick in the checkbox "enable connection serial cable or IR to this COM port" and choose from the drop down menu "IR port" BT port --> go to the BT manager on your PC, then "advanced config" and click onn thee nail "local services" - double click on the "BT Serial Port" and you will be prompted to the "properties" window that gives you a drop-down menu where you can choose the # of the COM port. You can also edit numbers in the System REgistry, but this requires proper care. I think the foregoing is sufficient for you
SOURCE: TK 380 diplays "FPU OLD!"
This means that you need an older version of software. to program the radio. When it comes to Kenwood the newer version software will not program the older FPU Version radios.
Patrick Patterson N5SLI
Radio Service tech Manager
SOURCE: I need to program Kenwood TK - 3100. I do not
I may be able to help. Where are u at? You can contact me at [email protected] with your info.
S.
SOURCE: unable to program tk-3207
hi, all i can think of is- A, the computer is way too fast for the program you are trying to run, what you need is a really old slow computer or B,
check the COM port settings on your computer.
click start, right click on my computer, click properties, then click on the hardware tab, then device manager.
then there will be a 'Ports COM &LPT' just make sure the com port number is the same one as you are using on the software. Hope this helps.
SOURCE: My Mio p350 no longer picks up satellites.
make sure that your firewall is not blocking the communication from the satelite.
