Champion 4 toilet leaks from the tank. I have replaced the flapper and cleaned the top and bottom plastic housing between the flapper. When the tank fills to the top it leaks to the bowl. the water level lowers to the bottom of the flapper and then stops. Any sugestions?
Yes. You will have to remove your tank from the bowl to replace the defective fill stack(the tube thing your flapper is attached to) it is not as hard as it seems.First remove water supply tube.Then remove the through the tank bolts. should be two of them. Lift off and turn tank upside down. remove spud gasket. Unscrew old stack. You should be able to get a universal kit to work with your tank and should come with all new parts including new flapper and spud gasket. You will need new through the tank bolts and note the sequence of assembly to get water tight seal on tank. Hope this helps
Water in tank runs about every 15 to 20 minutes
