It could be many things. Low battery, loose connections, if there is a low oil switche it may be low on oil. Your blade switch may be open, the clutch switch may be bad or out of adjustment. The seat has a switch so you must be sitting on it. Start with the battery, check the solenoid. Hope this helps.
SOURCE: Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
