SOURCE: unlock memory card
Password is the name of your memory card, so if you changed the name to your nickname or whatever that also acts as the password, although it doesn't say that at the time of doing it.
SOURCE: Username
Default for most DLink products is admin - and the password is blank. Other options are admin / admin or admin / public
The WBR1310 has had login problems in the past where it "forgets" its id and password. Pressing the reset button to get it back to defaults will get you in but you can't keep blowing away your configuration. DLink has newer firmware to correct this but others have still had an issue with this unit.
Good Luck!
SOURCE: cannot play diary girl game
when the pop out says go to the manual , at that moment press L button , R button and select at the same time it worked for me .
SOURCE: I forgot my xbox 360 password
Get your serial number from the Xbox and write it down then call xbox support at 1-800-469-9269.
They will give you a series of button and trigger pushes to enter to reset it.
SOURCE: Hello! My laptop is Acer
remove the battery for a few days (and all other power source). It should reset the BIOS
