SOURCE: Bluetooth is flashing red and blue
sounds like your in pairing mode ... use your phone to search for the device ... when its found the system will ask you for a code ... enter "0000"
SOURCE: bluetooth wont turnon new unit out of box
Pardon me if you have already tried this but with my em236c I had to hold the Answer/End button for about 15 sec before it flashed red/blue. The manual doesn't say how long to hold it. It took a couple of tries for me. Hope this helps.
SOURCE: old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
SOURCE: hitachi l32hp04u a my
hello coopa mark, usully it indicates on a powwer suplly problem.
some times its a bad capacitors
Turn on the Bluetooth
In Bluetooth Off mode, press and hold the Bluetooth button for about 5 seconds until a beep sound is heard and the Bluetooth button backlight flashes blue.
Press and hold the Bluetooth button for about 7 seconds to change to
Bluetooth pairing (linking) mode. The Bluetooth button backlight will flash blue and red. then go to the Bluetooth settings on your phone and select it there and enter 0000 for the default password
Then go to the bluetoothT
