SOURCE: Satellite Radio
Yes, but it will require a tuner adapter so that your deck will properly recognize XM. However for my deck I noticed that "Sirius" will still be displayed as the satilite provider on the display menu. Confusing but don't cause much concern.
SOURCE: 2005 Honda CR-V won't go to XM radio.
"XM Ready" means that you have to have a satelite radio installed in order to have XM service. I went through this when buying my 2005 CR-V and thought that all I needed was to set up the service. If you have an XM receiver installed you can controll it on your Honda factory radio. It is very misleading.
SOURCE: Rosen navigation system in my 2009 VW GLI w/no satellite radio??
Usually when it says sat ready, it means it is ready to control a satellite tuner that will have to be added on. I work on alot of cars that are satellite ready, and sell alot of radios that are satellite ready, and the all need a separate tuner for satellite. And yes, for the price, you would think it was included.
SOURCE: XM radio ''NOT READY'' message
I have had this problem at least a half-dozen times, and the simplest solution is to pull the 2 fuses labeled 'audio 1' and 'audio 2.' It resets the radio, but it will work for a while after that (until I have to do it again). Had the xm unit replaced 3 times, new antenna installed, replaced the antenna connection wire - it always dies within a month.
SOURCE: "not ready" message on XM radio
Remove the Audio Fuse and then put it back in and the problem is solved. So frustrating that I had to find this solution on another site as both the dealer and XM had no idea how to fix it. Dealer tried to tell me it was a bad radio and I'd have to get a replacement from Hyundai.
