After I push the start button, I turn the setting dial to off, then to a new run setting, the start button resets and clicks when I push it again. If I open and then close the door, the start button again resets and clicks when I push it. But there is no action from the dryer. No heating, no drum turning. I have reset the breaker to be sure there is power. I unplugged it and plugged it back in with the same results. Maytag Dryer, at least 15 years old.
SOURCE: Matag Dryer won't run
If the thermal fuse is blowing or the breakers when you bypass the fuse it means a part has a short circuit. There are more than one thermal fuses in there, so you will have to find where the one that blows is connected to.
My guess at this point would be that the motor or the start up capacitor are causing the fuse to blow but also check for a defective or shorted heater element.
Check this site for additional help: http://www.applianceaid.com/may-apart.html
SOURCE: Maytag MDG16CSBWW heating problem
HI thanks for the question. well ,you changed all the parts you needed to. but clean the venting from back, to the outside. thanks. please rate my answer. thanks.
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
SOURCE: Maytag MDG3000AWW Hard starting
your motor bearings or idler tensioner bearings are going dry and need repl
SOURCE: my maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
