I had the LC code flashing on my Samsung dishwasher and my mom also had the same problem with her Kenmore dishwasher! We tried everything everyone has posted and nothing worked!! Turns out it was an easy fix! Just add jet dry to the jet dry compartment on the inside panel of the door to the dishwasher and it worked!! No more LC code and the dishwasher now works fine!! I thought adding jet dry was an option?? Apparently it is a requirement with these new dishwashers!!
SOURCE: zanussi dishwasher ZSF6161 starts program then stops after 15 minutes
check this steps and fix it. God bless youFloat Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control.
