Cell Phones Logo
Tanmay saha Posted on Aug 21, 2018
How to get my PUK code, PIN2 code in nokia 3110c mobile
5 Related Answers
Anonymous
  • Posted on Mar 03, 2009
SOURCE: PIN blocked, Enter PUK cod:
My phone model is NOKIA 3110c and my phone no: is 9007611956. What is the puk cod?
Anonymous
  • 110 Answers
  • Posted on Apr 23, 2009
SOURCE: nokia 6010 asking for puk code, t-mobile brand
Because its PUK (pin unblocking key) that is provided from u r Cellular service provide they set the security for sim if u enter wrong puk more that 10 time u r sim will be block That not able to use again u need to contact u r Cellular service provide they will gime u new sim with same no.& if u not enter more than 10 time the puk code call there call center they will provide u PUK code.
Anonymous
  • 105 Answers
  • Posted on Jun 03, 2009
SOURCE: nokia 3110c mobile, i forgot security code.now how to reset security code?
plz downlod new softwear
Anonymous
  • Posted on Aug 11, 2009
SOURCE: pin blocked. I need PUK code for nokia 3110c
my pin blocked and i want my puk code
Anonymous
  • 94 Answers
  • Posted on Jan 13, 2010
SOURCE: nokia 3110c keypad lock forgotten
if you could get to settings menu and restore factory settings,your problem will be solved
Nokia 3110c - Mobile Phone. (IMEI Removed by Admin)******7901 My 3110c is restricted. I need a code.
This is a third world phone from 2007. Is it new to you and likely stolen? Does it mention PUK Lock or SIM Lock?
Here are all the Magic Codes.
https://unlockjournal.com/nokia-3110-classic/
I forget my password nokia 3110
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
1helpful
Pin2 blocked
Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
Jul 27, 2012 • Cell Phones
Sir my mobile is nokia 2626 and i want its PIN2 and PUK2 code please sir answer me soon
the two codes required can only be gotten from your service provider.
Call the customer service section of your network provider, request for your PIN2 and PUk, it will be give to you for free.
I hope the above is clear now.
Regards.
8helpful
4answers
I NEED RESTRICTION CODE FOR 3110C 354206/03/720307/7
RESTRICTION CODE FOR NOKIA 3110C 351939039190487
3helpful
2answers
How to format nokia 3110c
the better solution to this problem is at first you can't format 3110c
but there is a way which can solve the problems you face
1: Turn off your mobile
2: remove your memory card
3: Turn it on again
4: Go to Menu then Applications
5: there will be 2 folders games and collection
6: open each one separately and delete everything inside them>
7: Turn your phone off replace the memory card then Turn it on and have fun
2answers
How do you unlcok the P.U.K number?
The PUK CODE is not a code for mobile it is a code for your sim. you need to contact your sim's customer care and ask them for your PUK CODE then after getting the code insert it where the mobile is wanted to. then after inserting the code press ok then the mobile says to set a new PIN CODE set it to whatever you wanted to. then your mobile will works fine. don't forget to rate my solution.
73helpful
6answers
Nokia 3110c shows phone restricted undo
NOKIA PHONE 3110C
START ON
RESTRICTION CODE
Reset security code 3110c
security code has nothing to do with IMEE number. A word of caution if you try to change security code 3 times your puk will be blocked and you won't be able to use your sim for anything. Nokia keeps security code as 0000 So just go to settings and then security and when prompted give 0000 if it accepts well and good you get the option of change security pin change it to desiered pin. if not don't try to change your code or else your PUK will be blocked and you will have to make a long call to your customer care from your friends mobile.
4helpful
5answers
Nokia 3110c mobile, i forgot security code.now how to reset security code?
i forgot my security code of nokia model 3110c. my mobiles imei no: 353081029988329
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
