Question about Electric Electrical Supplies
No electric out put on my rockwood signiture ultra lite 8315
I have power to the breakers but no out put from there
3 Suggested Answers
SOURCE:
SOURCE: rockwood tent trailer (model 2318G) has no power
I have the same trailer and had the same problem. The trailer has a button that shuts off all power when the swing down stove and sink are folded down (this prevents anything from turning on when the trailer is folded down). The button is red and one of the wires came off the terminal.Once I hooked the wire back up everything worked fine.The button and is visible as soon as you fold down the sink and stove. The funny thing is that there is no mention of it in any of the literature that comes with the trailer
Posted on Aug 29, 2009
  • 336 Answers
SOURCE: Where can I find a manual for a 2008 rockwood signature ultra lite camper
Go to www.rockwoodcamper.com and send a request for a manual to customer service.
Posted on Mar 18, 2015
Would like to get an owners manual for a 2010 Rockwood Ultra lite, where can I find this?
Forest River (Rockwood is a model of theirs) only lists manuals for the past 3 years. You'd be better served and more informed if you write down make and model of every component you find in your RV. Then use Google to search for manuals for each system. These will include operating instructions, troubleshooting, and often parts. More valuable than the RV owner's manual.
Apr 26, 2017 | RVs
Reset button for a slide on a 2015 Rockwood signature ultra lite
check under front tongue red wires go to resettable breaker see if voltage on both sides if not replace
Oct 17, 2015 | RVs
2012 Rockwood 8288ws just purchased. When I turn the switch on for the water heater it cycles trying to ignite gas. I want to run electric only. What am I doing wrong?
1st Question - Can you verify that you actually have a Gas/Electic Waterheater? Most units are gas only. You may have to look at the unit and look for power cables.
2nd. Is power connected prior to turning on the water heater?
May 10, 2015 | Forest River 2012 Rockwood Signature Ultra...
Where are the circuit breakers
Look behind all cupboard doors higher and lower. Also look for a brown plastic cover in face of cupboards as well. Usually closer to where power cord enters from outside.
May 04, 2014 | Forest River 2010 Rockwood Mini Lite 2304
Lost keys to my Forest River 2013 Rockwood Ultra Lite 2703WS whats the easyest way to get in?
You may be able to climb in through the front storage compartment and raise the bed. Or, some mobile RV repair techs have a master set of keys and can let you in for a nominal fee. If you happen to know what the key number is then you can purchase a replacement key. FIC and Global keys each have 51 different cuts of keys. FIC will have a key code of HF or CF 3** and Global will have G3**.
Apr 06, 2014 | Forest River 2013 Rockwood Ultra Lite...
Rockwood trailer manual
Contact the manufacturer of the coach for their owner's manual. However, each appliance will have a separate owner's manual form its perspective manufacturer, i.e., Water Heater = Suburban, A/C = Dometic, Refrigerator = Norcold, etc.. There will not be a diagram of electrical or plumbing as a majority of the RV manufacturers do not publish that information. The only thing that I can think of that would cause the TV to reset when the Air Conditioner comes on is if the AC is remote controlled you may have a frequency conflict. It is not typical for the AC to share an electrical circuit with the TV but if that is the case here then the TV may be getting shut down because the AC is drawing too many amps on startup for the TV to continue to function. Turn the breaker off to the AC and see if the TV shuts down also. If it does then you will need to get the issue corrected.
Apr 02, 2014 | Forest River 2011 Rockwood Signature Ultra...
Rockwood camper manuel
Forest River appears to be the manufacturer so try them first for information
Jul 19, 2013 | Forest River 2011 Rockwood Ultra Lite...
Rockwood tent trailer (model 2318G) has no power
Jul 10, 2009 | Sport & Outdoor - Others
Electrical Supplies Logo
87 people viewed this question
Top Electrical Supplies Experts
Fahr Quad
NOEL
NOEL
vince
Are you an Electrical Supply Expert? Answer questions, earn points and help others
