SOURCE: error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
SOURCE: what do fault codes 12, 21, and 55 mean on a 1996
Code 12 = unplug battery recently (allways appear this code)
Code 21 = O2 sensor (the way to solve is replace it)
Code 55 = finish test
Good luck (remember comment and rated this post).
SOURCE: I have a Bosch classixx
Please check on the power , the program control panel and the motor drive- for mechanical jamming or failure of capacitor.
please check this link for help on Bosch machines.
SOURCE: maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
Bosch Washing Machine error code F21 .. Error message indicates a motor bushes replacement are required...or motor electrical fault.
