SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
SOURCE: Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
SOURCE: The deck belt keeps falling
Either the belt is stretched out and needs to be replaced or there is an idler/tensioner pulley that may be weak and not putting enough pressure on the belt.
SOURCE: NEED A DIAGRAM OF HOW TO ROUTE A BELT ON A TROY
type in your model number to your search engine. find your model and the diagrams will be there.
hope this helps.
