I have tried using different USB ports, I only have two. It's a mac with a duel OS, windows and mac both. Nothing is damaged on the mouse, and it works fine in other computers, just not on mine, window's side. The device has tried to install, but it never got past the first trying to find device bit. I can't find anything with wireless mouse in my downloads folder, or on my OS windows side.
Hi there!
Based on the description, I am going to make a logical leap and guess it's a Apple mouse? Specifically their Magic Mouse?
If that assumption is correct, boot to Windows and then follow this link:
AppleWirelessMouse64 exe
It is the Magic Mouse Driver for Windows 10
If it isn't a Magic Mouse, and is any other kind, feel free to let me know any details you can find on the bottom of the mouse, such as part number, or model number and I can help locate the Windows driver.
SOURCE: USB device not recognized
Try uninstalling windows version of bluetooth, then re install your adapter driver from the cd, but try in a different usb port.
SOURCE: Windows does not recognize USB connection to the SpeedStream 6520- malfanctioning
try using different USB port. if the it is unknown device. means the machine didn't recognized the device. you may have to install the device driver. (windows is a funny thing).
SOURCE: usb device not recognized problem
uninstall driver then turn off the PC then unplug the power cord from power socket, short its legs then leave it unconnected for 5min, then reconnect it to power socket and turn on PC and install driver it should work :)
SOURCE: USB Mouse does not work. Computer recognizes the device but pointer does not work.
Hii, you please check that usb mouse in another machine and if its working good then you need to install a driver from your motherboard cd or from the msi website.
SOURCE: Win Mobile Device 6.1 Vista will not Connect
Slmgato: have you tried to delete the old pairing on wmdc?
also to the other users: check the usb charge port on the tilt. Make sure it has not been bent or the pins have not been damaged. My tilt recently was damaged and now i can't charge or sync, but i can buy the replacement port for about 10 bucks and solder it myself.
