Heating & Cooling Logo
D
Dale Posted on Aug 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rinnai Split System F1 error code - Rinnai Heating & Cooling
Henry S
Level 2:
Sergeant:
  • Expert 301 Answers
  • Posted on Sep 20, 2018
Henry S
Expert
Level 2:
Sergeant:
Answers
301
Questions
0
Helped
194968
Points
720
You probably need to contact a service company. I cannot find anything on the internet with regards to your unit
3 Related Answers
Anonymous
  • Posted on May 21, 2010
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Anonymous
  • Posted on Oct 25, 2010
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
AJ Ken
  • 73 Answers
  • Posted on Jan 05, 2011
SOURCE: Trying to fix an AmcorAire AMD243HX system F1 code, not working.
We stock parts & have tech support for Amcor Mini Split Systems
[email protected]
201-266-8234 option 2
2answers
Rinnai Silent Servant error code 14 meaning?
Error code 14 on a Rinnai Silent Servant indicates a problem with the ignition system. Specifically, it means that the unit has failed to ignite after three attempts.
This could be caused by a variety of issues, such as a lack of gas supply, a blocked gas line, or a malfunctioning ignition module. It could also be caused by a dirty or faulty burner, or a problem with the venting system.
If you're experiencing this error code, it's recommended that you turn off the unit and contact a qualified service technician to diagnose and repair the issue. They'll be able to determine the root cause of the problem and take the necessary steps to get your Rinnai Silent Servant working properly again.
Error Code 11 appears on my Rinnai?
Rinnai error code 11 is an indication that there is no ignition in, or no gas supply to your hot water system. You can try the following to fix the problem: Check your hot water system for any visible damage or loose parts. Locate your gas supply and ensure it is turned on.
Rinnai Error Code 11 - Fixed Prices - Jim's Plumbing
General spilt AC showing f2 error how to solve it?
If have a mini split unit that gives an E4, E5, E6, F1, F2, F3 error code a few things can cause this problems.
How To Clear an E4, E5, E6, F1, F2, F3 Error Codes on a Mini Split
  1. Power off the unit and turn off the breaker or disconnect.
  2. Wait 2-3 minutes and power the unit back on.
Any problem that is not fixed will likely come back.
My Rinnai split system inverter is showing an F1 error code what does that mean
F-1-No communication between indoor and outdoor. Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
What means F1 error code in onida split ac
My onida inverter ac showing F1 error. Ac working but no cooling out door unit not working. Please find me a solution
Soleus dual mini split KFMHP18 fault error F1
F1 error code is a communication failure between the outdoor and indoor units. Check all inter-connecting wires. They should be minimum 14g stranded wire. Make sure all electrical connections are tight. These units are manufactured by CHIGO, you may try to contact them.
Rinnai 2532 error code 10
Error Code 10 Problem: Reduced or no air supply to the water heater or there is an obstruction in extracting the flue gases out.
Solution: Make sure that the recommended Rinnai venting is used, there is no obstruction in the venting system, no reduction in diameter and lengths are per instructions. Also make sure that nothing blocks the venting system or fan, and that dip switch and condensation collar are set properly.
Good luck,
Marty
I have an F1 error code. The manual states that this means the inside and outside units are not communicating. What should I look for
F-1-No communicationbetween indoor and outdoor. Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Top Rinnai Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
