Drills Logo
Edward Brause Posted on Aug 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ryobi 40V 2.6A battery. When I put it on the charger the charger blinks green for about 10 minutes and then goes to solid green. However, after 5 minutes of use my Ryobi trimmer dies. I repeat the process with the battery and get the exact same results. No charge level lights illuminate when I push the button on the battery either. I know blinking green indicates “charging” and solid green indicates “charged”. I cannot for the life of me figure out why the charger indicates a full charge while the battery itself indicates nothing. The charger is not the issue as everything works fine with a different battery and the trimmer is not the issue as it works fine with the second battery.
  • Edward Brause Aug 19, 2018
    Thanks. It is a lithium battery. It is basically a new battery as it hasn't gotten much use but it is also well outside Home Depot's 90 day return policy. Not the first issue I've had with Ryobi batteries right out of the box either.
    $100 down the tube unless I can find a battery store to fix it.
    Thanks for the info.
Vernon Taylor
Level 3:
  • Ryobi Master 7,446 Answers
  • Posted on Aug 19, 2018
 Vernon Taylor
Ryobi Master
Level 3:
Answers
7446
Questions
0
Helped
1960550
Points
26207
From your description the battery is probably faulty. If the batteries are still quite young it is possibly just one cell and while Ryobi don't refurbish batteries there are companies dotted around that do.
If it is a nicad battery, Ryobi told me just a couple of days ago they no longer supply nicad replacements and expect everyone to upgrade to lithium, which means also buying a charger.
2 Related Answers
Anonymous
  • 111 Answers
  • Posted on Mar 16, 2010
SOURCE: ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
speedw752
speed
  • Posted on Dec 12, 2012
SOURCE: ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
1helpful
My Ryobi 18v battery blinking green and does not stop.
The batter is faulty , perhaps one of the cells has shorted out .
I have two ryobi 40v batteries. One is brand new and they other is about two years old. The old one got the red green on the charger so I got a new battery. Got the same red green with the new battery....
Completely dead batteries may cause the charger to not see any load and it wont charge them. The way around this is to put the battery on the charger with the charger unplugged. Then plug in the charger and check the lights. Keep unplugging and plugging in the charger till it catches up and stays on.
Put battery on charger, no lights on. push power button green light comes on for a few seconds then goes off. No lights after that. Ryobi weed eater 40 volt
either battery is charged or battery is bad.
All chargers act different so I can't tell you. Try measuring the battery voltage with a meter. I assume you do not have another battery to try.
If the voltage is about 40V then the device might be bad. If it is much less (discharged) then the charger might be bad.
But the battery may also be bad.
A high internal resistance on the battery might cause the charger to think the battery is charged because it isn't drawing much current
Jul 20, 2019 • Drills
Why is the green light blinking on the Ryobi charger with the battery in it
My Ryobi 18V One+ charger blinks green while it's charging. When the battery is fully charged, the LED goes to a solid green. However, one battery recently had a faulty cell. After several hours on the charger, the green and red LEDs both were blinking. That indicated that the battery failed late in the charging sequence. It didn't fail the initial testing by the charger. The other battery I charged that day charged fine.
The extended capacity batteries can take 12 hours to charge in my experience. The regular batteries take less time. The charge time will depend on the battery chemistry(The older NiCd batteries take longer to charge then the Lithium batteries.)
I hope this helps. Assuming you aren't dealing with a cold or hot battery or charging environment, if you have any suspicion about a faulty battery, replace it.
(Note: I have a 12V drill as well. Those batteries takes longer to charge for the same relative capacity than the 18V NiCd batteries.)
I bought a Ryobi 12V drill w/ lithium charger. Green light on charger never went solid....continues to blink & fade. Does this mean its in the energy saving mode? Is it fully charged?
How long have you left battery on charger? It will take about 3 1/2 hrs to fully charge. t is probably not a good idea to leave the battery in the charger for long periods of time though, so once it is fully charged put it back in the drill. When fully charged the green led will turn solid. This link will have more info on charger and battery.
http://powertool.manualsonline.com/manuals/mfg/ryobi/130155001.html?p=2 C
1helpful
2answers
Green light on new Ryobi charger flashing when trying to charge battery it that normal
Yes, the green light flashes until the battery is fully charged on Ryobi chargers. This will change to a solid green light when the battery is fully charged until the charger goes to a power-saving mode. Not all of the Ryobi chargers have a power-saving mode. However, for those that do, the green led will dim over time and then brighten and dim slowly again in this mode.
My Ryobi charger, model P113, actually has a key for the LEDs on the unit on the left of the battery port. The manual for this charger is here: https://manuals.ttigroupna.com/system/files/5495/original/P113_192_trilingual.pdf?2011 . Ryobi has many of their manuals on their site. Look up your charger/tool here: https://www.ryobitools.com/power-tools/support/manuals , Home Depot's web site also has many of these manuals on the product site for the tools that they sell.
I hope this helps.
Ryobi 40v trimmer stops working with 1/2 charge left on battery
Battery is weak. Those lights are really useless...more a marketing gimmick. It almost sounds like it developed a memory...this happens when certain types of batteries are not fully discharged before being placed on the charger. Replace the battery and make sure to follow charging directions for that particular type of battery
3helpful
Ryobi 18v lithium battery won't charge
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
