Measuring Tools & Sensors Logo
Wayne McCauley Posted on Aug 19, 2018
User manual for Mars 65735 multimeter - Measuring Tools & Sensors
I need to now facts about mars now!
Mars is the fourth planet from the Sun. Named after the Roman god of war, and often described as the "Red Planet" due to its reddish appearance. Mars is a terrestrial planet with a thin atmosphere composed primarily of carbon dioxide.
Cohaagen will not turn the machine on, or he risks losing control of Mars. When the machine comes on, a hot reactor penetrates into an underground glacier, sending huge plumes of oxygen into the Martian atmosphere. This produces a blue sky on Mars, which coincidentally was a feature the memory scientists at Rekall INC were going to put into Quaid's memory during his visit.
which mars are you referring to is it Mars-22 car alarm
http://www.caralarm.com/manuals/MARS/MARS-22.pdf
or some other model like the mars 32 or mars 33
http://www.caralarm.com/manuals/mars/mars-32&33.pdf
or the planet mars
hopefully I have provided the correct model number above
Car stays running with omega mars #343-02 car starter
if you know how to get in to programming, That is programmable feature, You can change that to 10, 20, 30 minutes, I think yours is 30 minutes. This is the link for the owners manual,
http://www.caralarm.com/manuals/MARS/MARS-10&11.pdf
1helpful
2answers
How do you reprogram remote after replacing truck battery
Mine was doing the same thing. Find your Mars box, then...
Here is the link to get the manual.
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently.
3helpful
Motherboard shorted
Unless you have about a $3000 soldering machine and lots of skills soldering, i would say just get a new mobo. the cost to fix it would be lots more than its worth
Can my TV be used as a computer moniter?
Yes your model was designed so you can use it as a monitor. the user manual explains how to set it up.
2answers
I need a user manual for
Sorry no luck with a manual online. This link shows you all the dip-switch settings for the camera (just select the model); http://www.mars-cam.com/optical.html and if you contact them they will be able to tell you how to find a manual. Hope this helps :)
Top Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
