Televison & Video Logo
l
luis guillen Posted on Aug 19, 2018
40l261a12Dynex tv 40inch TheRed powerlight is onI push the power button to turn tv on light blinks and goes off andNothing happens tv stays off/light goes off too.i unplug and plug tvLight is on again
40l261a12 dynex tv 40inch. the red power light is on stand by light once i push the power button to turn tv on light blinks and goes offstan by light and nothing happens tv stays off/stand by light goes off too.i unplug and plug tv and red light comes again. thanks in advance
3 Related Answers
Anonymous
  • 555 Answers
  • Posted on Aug 05, 2008
SOURCE: LG MODEL (1 YR OLD)
How many red and green blinks to you see? (What pattern?)
AJIN G
Electro Med Services
  • 6694 Answers
  • Posted on Apr 25, 2016
SOURCE: Dynex tv model number DX-40L261A12 tv will not come on at all I unplugged it to try and reset it but it won't work. The red power light is on but every time I push the power button it does nothing
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
gopakumarg43
  • 76851 Answers
  • Posted on Jun 08, 2016
SOURCE: My dynex flat screen
Testimonial: "How do you enter it's service mode option"
I have a onn universal remote but there are no codes for a onn tv
Press the "Power" button on the TV you want to sync with the universal remote. Push and hold the "LED" button on the remote until the button lights up and stays lit. Push the "TV" button The "LED" light will blink once, then stay lit again. Point the remote toward your TV and press the "Power" button on your remote, holding it down until the TV turns off. Do not press "Power" again after the device turns off. Press the "Enter" button on your remote. The LED light will no longer stay lit. Your remote control is now programmed for use with the device.
Blinking powerlight on lc- c5255u
I just repaired this LCD tv exact same model.
symptoms- when the tv turns on, all I get is a black screen with blinking green light. No other error codes. It was crazy frustrating trouble shooting this. I measured the transformers on the master and slave inverter board with a multi meter. The resistance should be 1.31 k ohms. All but one measured within the specs except one. I get an OL reading. I took a chance to order this part on eBay for 13 dollars. After soldering it, the resistance for all of the transformers were back to specs. The tv powered on and stayed on. Works good as new. If anyone has the this similar issue I would advice testing the mini transformers on your master and slave inverter board. My email is [email protected] for help.
Sony trinitron kv-es29m80 tv has no led light
The blinks are fault indication. If the standby light blinks 10 times and the set shuts down after that;
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
2answers
Panasonic tv powerlight blinking,tv turning off and then back on, now it won't turn on at all, blinking green light goes red and it shuts off completely
My TV surname off after 5-15 minutes of use. The red light in the front blinks once every 3 seconds continuously. If I hold the power button down on the tv, it will turn on and do the same thing.
4helpful
Cineplus tv, loud popping sound, no picture? Warranty co. gone!
having a hard time turning on my Cineplus LC-32R25C
Cineplus 32” High Definition LCD Television...when i hit the power button..thered light on tv goes to yellow..as it it was in sleep mode..and i dont know wat to do to get it out of that state to turn it on..is there a sequense of buttons on the remote i gotta push to get it to work?
2answers
Blinking powerlight on front when i try to turn on tv
This is more likely a power supply failure. Most causes of tv failure are due to bad capacitors on either a system board or the power supply. In this case, it sounds like the power supply. You can test the capacitors with a capacitor tester to determine faulty capacitor. You can also test other components like power supply current with voltmeter or mulit-tester.
2helpful
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
4helpful
No picture on TV with powerlight on
If you press the power button *on* your TV (rather than using the RC), does the power light still stay on red rather than turn green?
TV won't turn on
I am having problems turning on the tv. I had lost the remote control so I bought a universal remote which was not working at the time I unpluged the tv form the powersocket then I tryed to turn on the tv the green power light stays on for a few seconds then it blinks two times then there isn't a power light on after that what is wrong
Top Dynex Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
