This error is a "Network Connection" issue.
I would restart all of the devices. Also remove the connection from the TV and then re-establish it.
If you don't have any special settings like port forwarding etc. set on the Router, I would factory reset it as-well.
Unless you're on dial-up, fresh settings on all the device should enable playback again.
SOURCE: Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
SOURCE: making connection between WII and internet and Netflix
Sounds like a netflix issue.Contact them with any information you have from them.Here is the link.
http://www.netflix.com/HowItWorks
SOURCE: connecting to netflix cannot find the location on
You need to connect to netflix via a PC or a Mac to get the access code for the Wii.
Go to your Wii menu, download and install the Netflix application from within the Wii Shop Channel, and follow the on screen instructions to connect your Wii to your Netflix account.
To connect via Wi-Fi go to the tutorial at
http://www.nintendo.com/games/wifi/wii
SOURCE: Hi. I am trying to
Goto settings date and time and tell ps3 you are on daylight savings time. Then delete Netflix and reinstall.
SOURCE: Error code 52230 - when trying to connect to
Unable to connect to your wireless network
Likely cause: Your router or Internet Service Provider is having difficulty assigning a DNS or IP address to the Wii.
How to fix: Manually assign an IP address and DNS to the Wii.
Assigning an IP address to your Wii is easy!
