Our Nordic Track machine intermittently runs its own diagnostic when you turn the machine on after it has been powered off. This includes the first time you take it out of the box. If you notice that the display screen is on but none of the function buttons work, listen for a humming sound at the base of the machine where the motor is housed. A tell-tail sign is that the motor that slopes the running track is raising or lowering the slope (as part of its diagnostic check) which is difficult to recognize when the track is not running. After perhaps one or two minutes, the button functions return and the machine "comes alive". If not, then you'll want to locate the Nordic Track service number and talk to a technician or representative.
SOURCE: Touchscreen buttons not working
the flexwire is the problem of your camera, the touch screen connection is already cut..go to a service center for replacing or repairing the flexwire...is not easy for repairing that if you are not a technician that wiring is like a strand of hair that why is difficult to fix but in our shop we modified that and become more durable than the original...
SOURCE: I have a NordicTrack A2250, about 2 years old.
Will the treadmill work when the chip is not plugged in, or does it just beep every time you select a button? If so, your problem is easy to solve. The board that supports the two adjacent up and down buttons has slipped. To fix, you'll need to remove the panel and remove the 3-inch retaining bar which is held in my two screws. Realign the board so the buttons are free to move in the available slots. Good luck.
SOURCE: I have a electrolux dryer
I have the same dryer....u have to unplug it for 30 minutes NOT 30 SECONDS to reset the unit.
SOURCE: I have a Nordictrack Solaris C2050 with the
I have the same issue I don't think anybody (including the supposed "experts") really know what they are talking about. The buttons work until they don't and then a bunch of them all stop functioning at once. The advice I always get is "replace the console" which amounts to saying "I don't know what's wrong" If I had to guess I think a static discharge has damaged the contoller board which doesn't manifest itself until the machine (and hence the board) warms up. Anyhow I haven't found a real solution to this issue if anyone has any real knowledge please post your solution.
