Refrigerators Logo
L
Larry Jones Posted on Aug 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a reset on my amana french door refrigerator ice maker
Steve Pack
Level 3:
  • Amana Master 7,128 Answers
  • Posted on Aug 18, 2018
Steve Pack
Amana Master
Level 3:
Answers
7128
Questions
Helped
2276167
Points
27978
5 Related Answers
Anonymous
  • 116 Answers
  • Posted on Mar 11, 2007
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 12, 2008
SOURCE: Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
Anonymous
  • 2028 Answers
  • Posted on Jul 08, 2008
SOURCE: Amana French Door Bottom Freezer Refrigerator making noise but not making ice
The noise you hear is the ice maker trying to make ice without a water supply. Check the line to make sure you didn't knock anything loose or kink it when changing the filter, and check for a plugged line. It could be that there is ice build up in the line, a defrost will cure that.
Anonymous
  • 1218 Answers
  • Posted on Dec 21, 2009
SOURCE: Amana Refrigerator Model # ARB 2214 CC with leaking ice maker
Good day,
If the fill pipe that fills the ice maker is in it's proper position, then it is a defective water fill valve located in the bottom rear of the machine.
After harvesting the cubes the ice maker mechanism continues to rotate and turns the water valve on for 7 seconds. If it does not shut off smartly then it can cause the well to overfill, and flow water into the bucket.
Do not let this go. A small leak could turn into a major overflow, even overnight causing serious problems to the machine and as I have seen the entire house.
Anonymous
  • 1218 Answers
  • Posted on May 26, 2010
SOURCE: Our Amana French door ice maker is clogged with
Good day,
What you have described sounds like a defective water valve on the back bottom rear of the machine. It will need to be replaced.
Although awkward, the best way is to remove the ice maker completely and let it air dry, while the valve gets changed.
The above diagnosis is based on the fact the freezer is maintaining it's normal temperature. If for some reason the freezer thaws and then refreezes that problem would need to be addressed first.
Hi, I have a amana af12538aes french door refrig. Starting this am, the control on the door does not deliver ice only cold water from the ice button. The ice maker is making ice. Is this a control...
Is the display flashing when you try and use it or can you hear the dispenser door opening and closing rapidly (clicking or clapping sound)? These are prone to the board going bad and losing the dispenser. Is the "ice" light lit on the dispenser? The touch pad could be bad too. Do you hear the auger motor turning the ice when you press the dispenser? or just the "shhhhhhh" of the water coming out?
If there is ice in the bucket then that is not the problem. Dump it and listen if you hear new ice drop to verify.
There is no such part called an "ice element". Ice maker-yes.. Heating element-yes.. Ice dispenser-yes
2answers
How do I remove the ice maker from the refrigerator?
Hello there,
To be able to remove the ice maker from the refrigerator, please follow the steps below:
  1. Unplug the refrigerator ffrom the power outlet,
  2. Open the door and unscrew the screws that mount the ice maker, there are basically 2 screws, for some model, there is a screw under the mounting that is holding the ice maker in place, but make sure you do not loosen the screws completely,
  3. Lift the ice maker up from the screws mounting it and pull it out from the rear of the refrigertor,
  4. You will have to squeeze the tab on the wire connector in order to remove it from the refrigerator wire harness.
  5. Then you can remove the ice maker.
That is how to remove the ice maker from the amana refrigerator.
All the best. Elect_Comp
Amana fridge. french door ice maker now seems to freeze overflow of water so i'm using hair dryer frequently to remove the clog. why is this starting
Your defrost assembly has probably stopped working, which means that you are probably also building up ice in between the panels.
Not making ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Ice maker stopped working aman abd2533deb
heatman101
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
