Computers & Internet Logo
P
Peggy Blount Posted on Aug 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change my wifi network. We have a new wifi network name
Dennis Crouse
Level 2:
  • Expert 44 Answers
  • Posted on Aug 20, 2018
Dennis Crouse
Expert
Level 2:
Answers
44
Questions
0
Helped
15201
Points
223
The trick is to tell the device to "Forget" the old Wifi network.
This is a bit different on Windows / Mac / iOS / Android but it all works basically the same.
Long press or click on the current Wifi and select Forget.
Connect to your newly named Wifi and poof.
2answers
TP-Link WiFi Range Extender. How do I enter a new WiFi address on my TP-Link extender?
Please check the side or bottom of the extender for the steps to update it's wifi signal. If not there, then please visit the extenders ip address through a computer connected to your home internet network, there might be a control page for the extender there. Otherwise, please use the table contents in your wifi extender's manual.
Thank you.
3answers
I want to change my wifi password
How to change wifi password Netgear?
Users are looking to know how to change wifi password Of Netgear Router need to follow the below steps:
    ·Launch an Internet browser and type http://www.routerlogin.net into the address bar.
    ·Enter the router user name and password when prompted.
    ·The default user name is admin. The default password is password.
    ·Click OK.
    ·The BASIC Home page displays.
    ·Select Wireless.
    ·Enter your new network name in the Name (SSID) field.
    ·Enter your new password in the Password (Network Key) fields.
    ·Click the Apply button.
    ·Your changes are saved. How would I change the administrator secret phrase on my NETGEAR router?
    At the point when you purchase another NETGEAR router, it is arranged with production line default settings. At the point when you utilize the nearby web address www.routerlogin.com to get to your router's web interface, the client's name is the administrator and the default secret word is the secret word. To improve the security of your system, change the default secret phrase.
      ·unch an internet browser from a PC or cell phone that is associated with your router's system.
      ·Type http://routerlogin.net into your internet browser's location bar.
      ·Snap Enter or tap Search.
      ·A login window shows.
      ·Enter the router client name and secret word. Note: The client's name is an administrator and the default secret word is secret word.
        ·The BASIC Home page shows.
        ·Select ADVANCED > Administration > Set Password.
        ·Type the old secret phrase, and type the new secret key twice.
        ·To recuperate your secret key, later on, select Enable Password Recovery.
        ·Snap Apply.
        Source: http://www.buzzmeweb.com/how-to-change-wifi-password-netgear
My seiki tv detects wifi but won't connect. even after i enter the password. how do i fix this?
One reason I can think of for your problem is this: your TV detects several other protected WiFi networks (probably from your neighbors) in addition to your own, and it is likely that you entered the password for your network when trying to connect to another network. To check if this is the case and if you don't know your network's name (actually this is called the network's SSID), do the following: turn off your modem/router, then check what WiFi networks are detected by your TV. Write down the names of those networks. Turn your modem/router back on and see what networks are now detected by your TV. The new one on the list is your WiFI network's SSID. Make sure that you connect your TV to that new network.
2answers
How to set up netgear ex6100 wifi range extender
  1. Plugin your extender in electrical outlet.
  2. Place your extender near your router when first time your are setting new extender.
  3. Launch any web browser and enter mywifiext.net. The New Extender Setup page displays.
  4. In the Password section, type the existing WiFi network password. Default user name is admin and password is password.
5. Click continue and a message box displays saying that your extender is connected to the new extender WiFi network
6.
Now, you can connect your device to the extender network, go to the WIFI settings and connect to the extender's new network.
7.
Netgear EX6100 Setup is successfully completed now place the extender at the desired location and enjoy seamless Connectivity.
2answers
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Cant set up wifi on my new tablet
To set up your WiFi network, tap the Menu Key > Settings > Wireless & networks > WiFi settings. If WiFi is not checked, tap WiFi to turn wireless on, and wait for your tablet to detect nearby networks. Tap the name of your network and enter a security password, if required.
WiFi networks that are configured as private or closed do not display the network name on WiFi-enabled devices. To Join a closed or private network, tap Menu Key > Settings > Wireless & networks > enter the WiFi network name, security, and password.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
How to change wifi name in router
The wifi name you are referring to is called SSID, service set identifier. You can change that by logging onto your routers Web based utility. Open your web browser and type in 192.168.0.1 and it will ask you for a user name and password. If you keep the default user name and password the user name should be admin and the password is blank, meaning there is no password set up. After logging on, click on top tab "Setup" and on the side menu "Wireless". You should be able to change the SSID by typing in a new name in the field "Wireless Network Name". Make sure you save the changes! This should then change the name.
Recently secured wireless network with a new name and password. Can't get on Netflix now.
You need to go into your network settings for your Wii and change your Wifi network settings to reflect the new name and password. Your WIi is looking for a Wireless router named whatever you used to call it and not finding it.
My wifi name just got changed from NetGear to AMERICANRENTAL2_Network. My iPod was connected to the other wifi connection name. This new network has a password, I figured out a way to get my laptops...
1.Take a Ethernet cable and attach it with your router and one of your pc
2.open internet explo and goto 192.168.0.1
3.user name=admin password=password
4.now a web interface willopen and you can setup your router.
Grand Canyon Tech
Grand Canyon Tech
