SOURCE: Set Tax rate on a Casio HR-100TM
Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate.
SOURCE: Cannot change +5% TO -10%
To chance tax rate follow this:
Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key and then press the TAX+ key. It should save the new tax rate.
I'm not sure if you can set negative tax values. I believe it is meant for positive tax percentages only.
Chris
SOURCE: how to load paper in
Put the roll on the arms "like a toilet paper roll on the extender", and pull it under. There is a slot, slip the paper into this slot, and press FEED until the paper reaches the ink.
