SOURCE: how refill my tank of freon 134 in my machine ?
Fix low side coupler to R134a refrigerant sorce (new refrigerant tank with up side down & tank valve open) tank.Open low side manifold valve & close high side manifold valve.press tank re-fill or recover botton & fill as you want.NOTE: Max.cap.50 LBS or 23 KG.
SOURCE: i have a robinair cool
You may have one of those problem. 1# Machine is showing wrong weight. if so you need to re-calibrate the scale. 2# Check tank ''LIQUID'' hose is connected (one of three hose on the tank which is marked with -Vapor - Air purge - Liquid ) to the tank properly, make sure it is not loss or over tight. Hope this will help you to solve the problem. if so, please vote for it. wish you good luck!
SOURCE: Hi, My robinair model 34700Z
It is clear to me you need to Replace the Compressor! But if you want to make sure yourself, please do the following: Press recover & fix a vacuum gauge on your machin Compressor suction port & monito the gauge is going up to13"HG suction,if not then you need to replace the compressor.
I wish this will help you to solve the the problem. if so, pls vote for it. Good luck!
Testimonial: "Thanks, I will try it"
SOURCE: I have a Robinair 34430 that will not charge,
You can do the following :
1# Rebuild/Replace ''charge'' solenoid.
2# Check ''recover'' solenoid is working properly. Repair as need. If recover solenoid is OK, Then you may have to replace the "Compressor".
I hope this will help you to rectify the problem. If so, please vote for solution. Best of Luck!
SOURCE: I have a Robinair 34700 A/C machine that the freon
YOU NEED TO REPLACE OIL DRAIN SOLENOID OR OIL DRAIN SWITCH
