Ok, 10 year old laptop
step1 , as always remove the old dead shorted huge battery first.
run now? it will on AC for every if you want.
Led Glowing tell not much its just and LED, so dont look at them if on, unless and LED blinks codes. ok?
what matters is power, power is first. no power no joy, ever.
so out the battery now.
Put in a new RTC coin cell battery next 7 year life rated you are 3 years past that at 10 years old, (end of useful life that)
next is fans, , ok fan is on.
next is what, TEXT got TEXT ON SCREEN>? ANY THING??
I guess ZERO SCREEN anything of any kind>.
we next use a flash light, this PC has crummy , CCFL back lamp tubes that when dead screen goes, dead, as most have this old.
only few never used laptops last 10 years old.
so with the flash light (dark room) at an angle shin the LCD
see data, now on the screen, yes, that is a DEAD CCLF.
on ebay you see them selling new CCLF screens for this PC.
my bet the CCFL are dead. as most are this old.
All laps this old fail in this order,
BIG battery goes bad or shorts.
COIN cell dead.
CCLF dead ( ended about year 2010 , LED back lamps began)
HDD dead at 5 to 10 years old.
this is all Expected. all from carbon14 dating a PC, I can say that.
yours is 2008 made.
SOURCE: Acer Aspire one screen stays black
i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
SOURCE: Acer aspire 5570z white screen
its either going to be a problem with the lcd, inverter or output from the motherboard probably.
Best thing to do is to try a different lcd with a different lcd cable, then if that doesn't work, then try to get a different inverter, if that doesn't work then you'll know for sure its the output coming from the motherboard.
Alot of times the LCD's go bad but the lcd cables go bad cause they are flimsy and the wires break inside.
Look on Ebay cause you can easily get these parts cheaper then most places.
SOURCE: Acer Aspire SA80 197Z Power Up
Well, the best thing to do is to take it to a computer technician to get it checked up. This is the reason why you want somebody knoweledgeable:
1. It may be a problem with the Power Supply Unit (PSU).
2. Could be a problem with the power button (Internal failure) and to check it, you have to manually jump the motherboard at the power button connector.
3. It could be also a motherboard failure (probably caused by a power surge the day before it failed).
If you want to check for the a solution for youlsef, check online on how to do a check up on the three items I mentioned before. Good luck (Please leave a comment if this answer helped you somehow).
SOURCE: acer aspire 3680-2682 powers on but black screen
you can referen the article:
How to Fix a Black Screen at Startup
maybe
it can give your some help
SOURCE: ACER Aspire laptop power cycles on and off
Sir, form the symptoms I believe that the Battery is completely dead, the system is unable to identify the battery. If possible try checking the battery with a similar model, and the the system should be all set to go.
please encourage us,if this tip was helpful to you.
