SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
SOURCE: zanussi fridge freezer frostfree ZX 57/3 W not working
It sounds like you have a plugged defrost
drain line. This is where the water goes to in the bottom of your
freezer when it goes through the defrost (removal of ice from the
freezer coil) cycle. It sounds like that hole is plugged and now the
water/ice has now frozen in the vent that lets air circulate down into
your refrigerator compartment. What I usually do in this case is to
unplug the refrigerator, empty out the freezer compartment. Usually I
also end up either pulling off the back panel or the bottom panel (in
the freezer compartment) Looking for that defrost drain hole and
actually I use a hair dryer. I can sometimes do this also by pouring
small amounts of HOT tap water onto it and then sopping/absorbing it
away with a sponge or dishcloth. I repeat this until I get the water to
go down the drain tube.
Hope this helps,
Sai.
SOURCE: The freezer is working but the the fridge
same here. have the znb 4051s refridgerator. freezer works fine but fridge does not. there is no sound eminating from the fridge either...any ideas? its 1 year old!
SOURCE: fridge doesn't work but freezer does
i have had the same problem, it was the fan which needed to be replaced.
SOURCE: ZANUSSI ELECTROLUX -- FRIDGE (TOP HALF) NOT WORKING?
9 times out of ten, when the freezer portion works, and the refrigerator portion doesn't, it is the evaporator fan that is the problem. I am not familiar with that model, so I do not know where the fan is located. But there is a fan that blows cold air from the freezer into the fridge portion. Usually, a fan blade is just stuck, and just needs to be repositioned or the bearing the motor spins on could be frozen or rusty. I little household oil usually does the trick, or you might need a new fan motor.
Another possible cause is the ice that can build up. If there is ice blocking the air's path it will have the same result. You said you had defrosted the unit, so this is not likely in your case
