You have mistakenly posted your issue on FIXYA.
This is FIXYA, not Just Answer.
Contact Just Answer or your financial institution for a refund.
https://en.wikipedia.org/wiki/JustAnswer
SOURCE: answer
If this were something in the states it might be easier to figure out.
The only thing I could suggest is make sure the firewalls are turned off.
Is this a broadband or dial up connection?
SOURCE: On 23/03/2011 the amount of
when you created the account, a confirmination email was sent to you, the same when when you recived an answer ,, did you check your emial account especially the spam folder ???
using the username and password you provided you can log back into fixya from the sign in to the top, use this tool to view your previous questions and solutions.
Now I'm just an expert here that spotted your post, Click this
http://www.fixya.com/contact
and tell them about what happened, They will assist you..
SOURCE: Hi, i am from South
The Chrysler group from South Africa will be able to help you. Here is the link with phone number.
Good luck, i hope this helps.
http://www.chryslergroup.co.za/mopar.asp
SOURCE: How can I activate blackberry messenger on blackberry 9930 in south africa
You first need to buy R60 airtime for the network you are using such as MTN, Vodacom, Cell C etc. That R60 will be the amount you need for (BIS) Blackberry Internet Service. You need BIS to enable BBM (Blackberry Messenger) to work. Once you have topped up your airtime with R60, you need to dial *141*11# which should bring up the option to activate BIS. Choose BIS and not any other option. BIS is usually option 1, but just make sure you select to activate BIS. Once BIS is activated then you can go onto BBM (Blackberry Messenger) and you should be able to send messages. You then have internet access as well. The great thing about the BIS is that it lasts for a month, without you needing to pay anything after the R60 to send as many messages as you like for free on BBM, plus you can use the internet on your phone as much as you like too! I am experiencing a problem getting BIS on my Blackberry Curve which I shall ask a question about on this site!! Good luck :)
